Magneto coils came in. Installed and engine running like new, or better.
I say "or better" because the air gap was way off originally (about 0.003" instead of 0.010") and it sounds like it is running faster than it was right before replacing the coils.
What is the RPM supposed to be with throttle lever in the detent before going into the choke position?
Looks like a lost spark system (plugs spark on exhaust stroke as well as compression stroke), so there will be a spark on every revolution for both cylinders.
