d140 Transmission
Barrie1
How to remove transmission to change fluid
Normally you don't change the fluid unless there is a problem.
It is a fully sealed system that was assembled in a clean room enviroment.
There is no drain bolt because you are not supposed to change the oil.
The tranny has to come out of the mower to drain & refill it.
