babatsetse
Hello!
After a year of use of my JD D110, I ran into a large rock and the belt snapped. I went out to Lowe's and bought a new belt that clearly says it is for a D110. I installed it (pretty simple) but the new belt looks loose and it falls off after a few minutes of use. I looked for info online and it seems like most JD mowers have two bolts you can unscrew to adjust the tension of the cable. However, my D110 has a static metal piece welded onto the deck and I see no way to tension the cable properly. How does one do this? I have looked and looked... Thanks!!
P.S. I should say I purchased the D110 new from Lowes in 2017.
