popsthemachinist
- Oct 14, 2021
- 1
- 3
Hi I have a 2011 D105 with about 130 hours on it. I replaced the variator assembly with the problematic washer. My washer wore completely through and the spring broke. I dropped the transmission, replaced the assembly, cleaned everything out well and reassembled.
Everything started up and worked just fine, except it feels like it is stuck in granny gear. Forward suddenly goes very slow. I took apart and reassembled two more times and I cannot see anything not working correctly. The belts seem fine, all parts move fine, shifts from fwd to neutral to reverse fine. It just goes really slow. Any ideas on what could have caused this? It drove fine and as fast as it ever did until I changed the variator.
Thanks
Thanks
