Fireman 123
Can the same needle bearing that's used in the armature plate, also replace the bronze bushing in the lower end? Can these bearings, and seals be matched up at a local auto parts store vs. buying an over priced LB part? I realize the rod bearings, and rings will need to be specific. Just hoping to do this on a budget. Thanks for any response.
