sofasurfer
- Jun 1, 2020
- 26
- 58
Briggs & Stratton Model # 135212.
Seized the engine. I think the piston can be cleaned up. The rings are ok. Looks like the metal came off the cylinder wall and attached to the piston. If I can not hone the wall all the way to remove the gouge do you think it can stlll run with some gouge left in the wall? This is from a chipper. Heres the pics...
