smalltimerpm
- Feb 4, 2023
- 5
- 84
Having issues with rpms dropping under a load. It runs great but it is sluggish getting up to high idle. It runs great and doesn't miss. Once I move forward or backwards the rpms will drop dramatically and pick back up. It gets worse with pto engaged.
I've pulled each plug wire off while running but both have same effect and it almost dies... if not does die out. I haven't put a compression gauge on it I just did the old blow the thumb off the hole trick. It seemed to have good compression. I've been thru the carb, even replaced it with one I know works great. Has good fuel flow. The spring travel seems to be the same on all valves but the lifters are hydraulic. Any help would be great. Also the motor does have about 940 hours on it and not sure if it's been gone through or not.
