Hi. New here. Reading various threads, appears there are experienced folks and numerous professionals onboard. Good - I could use a little help.
Have well-maintained Kohler CV730 in little Husq. Suburban tractor that sees limited use for clippings/mulch pickup. Firing up after winter storage, starter ran & turned motor over a few times, then quit. Since then, starter will not energize, but I can hear solenoid click each time ignition switch is turned on and then off again. Since starter was original from '06, I replaced it, but with new starter, same condition persists. Wondering about the Regulator/Rectifier [15 amp]. Is that suspect here?
Only other thing I can think of is ignition switch, but solenoid is sounds like it's working correct, lights work, etc.
Fresh battery is fresh fully charged.
Your thoughts appreciated. Thanks. ~Hank7
