CV680, build date 2016. Has had frequent oil changes. Was running fine, then suddenly quit running.
Rocker arm screw on one valve loosened and the valve components self-disassembled. All components appear to be OK.
Rocker arm screw is 6mm x 1.00mm pitch. Since it loosened on its own, I was thinking of using Locktite Blue 242 (for removeable fasteners) to keep it in place. Package instructions say, "If two inactive metals are used, then primer is required". The head is aluminum and the screw is steel, so it's two metals.
Primer? No primer on the display where I get the blue 242.
Any suggestions?
Any suggestions?
