- Sep 24, 2017
- Threads
- 251
- 6,450
Great. Thanks for the confirmation.that is the size of the one in the 12 757 03-S repair kit here.
Yeah, Walbro doesn't provide parts for carbs they build for Kohler. You have to get the parts from Kohler. Would you be able to provide the number right off the carb? It will be 12 053 and two more digits.Okay, well now I need a throttle shaft kit... still surging and I've got air coming through the shaft. Runs fine if I give it carb cleaner at the throttle shaft... I figured it would be a problem.
I'm not seeing one on the Kohler IPL.
Shows N/A from Walbro
Sorry it took a while to get this info but with the holiday they just re-opened today.
