GearHead36
- Apr 26, 2023
- 14
- 231
I have a Husqvarna CZ 4817 Zero Turn Mower (968999220) with a Kohler Command CV490S. It has the common leaky carb problem, so I I'm taking a gamble on a cheap Amazon carb. However, as I'm putting it back together, I notice that the throttle is not wide open with the mower not running. I can move it by hand to full throttle, but the governor is not doing it on its own. I'm wondering if I'm missing a spring somewhere. Can someone provide a diagram of the throttle & governor linkages for this engine?
If not an external spring, then what would be the problem? I'd guess something internal.
Maybe this explains why I've had problems with this mower bogging under load. There have been times when the grass was thick, and when mowing up a slope, I would have to slow down. Maybe it's hasn't been getting full throttle for a while.
Edit: Resolved. Go to my next post for the answer.
