I was not getting gas to the carb. I changed the fuel filter, and still had the problem. Line is in OK shape -- no leaks. I siphoned gas into the filter, and then kept the motor going by pouring gas into the carb. After about 8 ounces of gas, the pump started working. I mowed the grass and then started it again the next day. Did I revive the pump?
