cub fuel pump
remmel
I was not getting gas to the carb. I changed the fuel filter, and still had the problem. Line is in OK shape -- no leaks. I siphoned gas into the filter, and then kept the motor going by pouring gas into the carb. After about 8 ounces of gas, the pump started working. I mowed the grass and then started it again the next day. Did I revive the pump?
If it is like my cub, the bottom of the fuel bowl was dry and by pouring the gas in the fuel pump refilled the carb bowl.
