Cub Cadet ZT1 42 - Carburetor Controls
roger9841
Is there any documentation that shows the installation of the springs and other assembly details for the carburetor controls of a KT725 V-twin motor on a Cub Cadet zero turn. The maintenance manual only shows the front view of the assembly. There is a long spring and rotary spring on the back of the assembly. TIA!
Great picture references. It is that bottom governor arm spring.that connects to the bottom of the Govenor Arm - where does it connect on the other end? It is behind the main bracket.
