Auto Doc's
- Sep 7, 2024
- 23
- 1,940
I have this CC Z Force that has no power to the anti-backfire solenoid with key turned on. Solenoid tests good when powered manually.
Mower Model number 53AA5A7M710 w/ the Briggs & Stratton engine.
Engine runs but only with full choke on to suck fuel past the solenoid plunger tip. Carburetor is clean and no wire damage has been found at this time. Key Switch is suspect, but I need wiring diagram to confirm. I don't throw parts at problems
