ViennaSteve
- Jul 19, 2023
- 1
- 2
I have replaced the battery, starter, solenoid, regulator and Hour Meter Service Minder Module. This is the most stubborn problem I have ever had. This thing just will not start. Engine has only 38 hours. Battery has 12.4 volts, but that ain't enough to turn it over. I can jump it with my truck which provides 14 volts. At one point (before I replaced the regulator), my truck provided enough voltage to turn it over and start, but the engine died the moment I removed the jumper cables. So I replaced the regulator. Things got worse. The solenoid engages the starter and the engine turns a bit, but does not turn complete rotations enough to start.
Why is 14 volts not enough to spin the motor?
I'm truly at a loss as to where to go from here; I don't know what else to check.
Any ideas?
Any ideas?
