Cub Cadet WST100
Dmuzkman
Brush mower ie heavy duty weed eater. Runs fine after initial start, new plug, new carb, new air filter, new gas. Engine uses a vane and exhaust type of auto choke. The choke is initially closed. I give it one shot of start fluid and it fires up and runs well. The carburator has only one adjustment. Any tips would be appreciated.
5T65RUB Engine.
Check for air leaks.
