garry6913
- Jul 3, 2023
- 1
- 30
I have a Cub Cadet Lt1042 that was giving me problems. It had a Kohler SV600 20 hp motor in it. It would keep shearing the keyway. it really needs a new crankshaft and flywheel. Near the keyway is a chunk missing and on the flywheel there are a few deep grooves. I have tried JB weld to a epoxy i used at a place i worked we used for motors and pumps and it sealed everything up. Instead of spending about $300 ( $85 used crank and $200something for flywheel) i had a running Briggs and Stratton 21 hp Intek V Twin Cylinder motor. I swapped the motors. The Briggs motor pops, burps, farts, backfires through the carb and muffler. When i do get it running it idles nice but has no power to move. I have put new plugs in it, changed the carb with new fuel solenoid, adjusted valves, checked timing, (now it wont run at all after checking) and drained all old gas out and put in new gas. The motor sat for about 2 years. It acts like too much gas is going into the cylinders but when pulled the plugs they were little carboned up and no gas on them. After changing the fuel i did clean and change the fuel filter and pump and took the carb back off and cleaned it again as a precaution that the gas was bad. When the fuel solenoid is unplugged it sounds better when trying to start. Only thing i haven't done is check compression. In spinning motor over without plugs in it and fuel disconnected you put your hand over spark plug hole you can feel good compression. exhaust isn't plugged either.
