Cub cadet tires
Tdear69
I need new tires and I want to know if on the rear it has 18-9.5-8 tires and I want to get 18-8.5-8 because I can get them in flat free tires can’t find the original size in flat free so will that size work?
Tdear69
If anyone can help me I would appreciate it have spent the last two days researching it can’t get a good answer although one site said it should not matter but not a straight answer
The flat free tires are the same diameter on the same size rim, but just 1 inch narrower in profile. if they will mount up then you are golden. The reason I said that is most flat free tires come already mounted on the rims and that would be the deciding factor.
