With the engine running, the oil light comes on for about 30 seconds, then goes off and after 30 seconds, comes on again --- on and off ----- what causes this???
The oil is full - I changed oil filter and still does the same thing --- Yet, the engine runs fine.
Where is the oil pressure transmitter located on this engine. Thanks for the info.....Maryann
