Hey everyone, I have a new to me SC900 rear wheel self propelled mower. Had been running great, only used a dozen times or so until a month ago....
Was taking a long time to get it to fire up.. over time, it went from 1 single pull, increasing over time to 6 or 7 pulls, then up to a couple dozen pulls or so to get it to cough and start.
Now it won't start at all.
What I have done:
*Pulled & inspected plug (plug looksd but is getting wet after multiple pulls ((obviously it's getting fuel)).
*Grounded out spark plug to verify spark ( no visible spark)
*Pulled fuel tank off to inspect "kill switch"
This is what has me puzzled. I have never seen a kill switch designed this way. I'm confused on how this can work if when squeezing closed the safety start lever and pull starting the mower, the metal kill tab makes contact with the metal pivoting arm....but when you let off the safety lever, that same metal grounding tab makes contact again, just on the opposite side of this same metal pivoting arm.
Can someone explain how this works and whether it should be doing this. I would think it should ground out only when releasing the safety lever.
I'm assuming my issue is either the kills switch (which may need some adjusting or a faulty coil module).
And yes, mower has fuel
Thanks
What I have done:
Thanks
