BarryCripps
 - Jun 4, 2012
- Threads
 - 2
 - 4
Hey guys, I just acquired my CC RZT54 KW used. I'm told that it has about 200-250 hours on it, but the hour meter doesn't work. It seems like a bit of a rare problem that something like that would cease working, so I'm wondering if something else could be the cause.
The previous owner disconnected both the Reverse PTO safety cut-off switch, and the seat safety cut-off switch, because he wanted to mow backwards, and be able to jump off the mower while the blades are engaged.....which is a little fool-hardy if you ask me.
The question is, could disconnecting these switches have un-knowingly also deactivated the hour meter......or could my meter just actually be dead?
Thanks!
Thanks!
