Although this mower is several years old it only has 56.1 engine hours are on it. Yup it has always had the backfire when turning it off...more than likely a sharp edge/casting flaw in the combustion chamber not removed before assembly. But now it has the problem of miss firing, spitting, backfiring when under a load. First I simply drained the carb bowl thinking water or a speck of dirt and saw nothing. It ran fine following this bowl drain. But did not solve the problem. I was fixing to check, clean and regap the plugs when I looked online and read about all of these issues about valve clearance, valve guide, ignition module problems and said why not join the forum and ask. In 2010, shortly following the purchase of the mower I saw a California (where else) class action law suite concerning the claimed HP output of the engine being over rated and joined the suite and spent my $19 as a result of the suit. Said to myself, yup, got a great deal on the purchase of the mower but maybe because of the Kawasaki engine a lemon now will bother me each time I mow my yard.
Someone posted the valve clearance to be .004-.006. Is this a cold or hot engine measurement? It seams to be getting plenty of fuel but I will check the fuel pump impulse hose. The ignition module sounds like a buy it and try it proposal. Anyone find the same issues and find a resolution to the miss firing?
Thx, Bill
Thx, Bill
