jwhitemx15
- Apr 14, 2013
- 1
- 3
Hi all,
Ran across this forum and hope someone can help me. I have an '05 RZT 50 that will not turn over. Late last fall I had a battery running down and continued to crank until it slowly and finally drained too far down and wouldn't turn over the engine any longer. (i know, stupid move to keep cranking with a questionable battery).
Anyway, I replaced the battery, I'm getting 11+ or 12+ volts when I turn the key, but I get absolutely nothing. It's like a safety switch is keeping it from turning over the engine. Brake is on, levers down, etc. I also removed the seat switch since my seat is a little messed up. I removed the seat switch and twisted the wires together, but still get nothing when turning over the key.
Also, I did take a screwdriver and touch both posts on the solenoid and it did turn the engine over. Anything else I can try? Is there a way to bypass all of the switches to get it going or something?
Thanks,
Jeff
Thanks,
Jeff
