Cub cadet RTZ50 not starting
Kray
My 2005 Cub cadet will not start. I have replaced the battery and it still won't start.
The hour meter and other lights that normally come on before turning the ignition key no longer come on.
Thanks for the information. I replaced the fuse, but it still doesn't start. I turn the key and still get no lights on the display and when I turn the key it seems to try to engage the starter. Is there anything else in line that could cause power to not get to the panel?
Check with both hands everything electrical, backside of ignition switch, all relays, switches including seat switch, if battery is questionable remove & take to auto parts store & have them load test battery at no charge to you.
