Cub cadet part broke.. help identifying please
platinumaa
well.. something now broke, actually burned than tilted this part.. can someone please look at these pics and tell me what part i need to order to get this replaced?.. 2006 super LT 1550belt wobbling
not sure if this damage is related to my previous post about the
also, suggestions on how this happened and can it be prevented.. or is it just standard maintenence.
[/IMG]
[/IMG]
thanks
tony
CajunCub
Blade shaft spindle......Man, you've been workin' that Cub!:eek:
platinumaa
is the "Blade shaft spindle" hard to replace once i order the part?
thanks
tony
No its pretty easy but assume that the four mounting bolts will break off when you go to remove them so it wouldn't be a bad idea to also get new bolts to put the new one back one.
benski
Some Never-Seize is also a good idea.:cool:
