May 2009 Cub Cadet LTX 1050VT is leaking oil down from what I assume is the seal on the shaft that comes out of the engine. The oil is getting on the drive belt and causing it to slip when mowing up hill were I have not had a problem before.
I have faithfully changed the oil and the oil filter since I bought this machine. Why is this six year-old machine leaking oil? My yard is such that I can mow the whole thing in just under an hour.
I live in Michigan so this mower is only used about once a week from May to about the middle of September. Is such to be expected of a machine that is used this little? Or is this par for the course (to be expected), for a six year-old machine with that amount of use?
The engine is a Briggs & Stratton Model 44M777 Intek Extended Life Series.
