good evening. I am having a problem removing the forward idler pulley for the tractor drive belt. the other two come off easily. the forward one even after the bolt is backed right off there is no way it drops down. thanks in advance.
no not the engine. there is a pulley on the trans, one on the engine and three idler pulleys. it is the forward idler pulley.
I am having trouble figuring out what it is bolted to....
