I have an LT 1040 lawn tractor that I bought in approx. 2009. Recently (the past few months), I've noticed that the right side blade doesn't cut too well. After a pass, there is still some longer scraggly grass remaining seeming as if the blade is very dull. I am not cutting excessively high grass (maybe 3~4" long at most). I figured it was a blade sharpening issue so I resharpened it to no avail. I still have the original blades installed and have always used the mulching plug on the deck. I called my dealer and they serviced it including sharpening the blades.
I get the tractor back, same issue. I have the dealer service rep look at it and he agrees there is an issue. He sends a tech out and he can find nothing that would cause my issue. I always set my deck cutting height at around the 4 setting. He suggested removing the mulching plug so the grass simply discharges out of the side shoot from the deck. That seems to work better but still not perfect. The dealer is at a loss as to what is causing the issue and so am I. Anyone with suggestions on how to fix this?
Thanks.
Thanks.
