Whateverly
- Jul 9, 2014
- 2
- 3
I am trying to determine how to properly install a Briggs I/C Platinum 19 hp twin turbo into my Cub Cadet LT 1045. The previous owner replaced the Kohler engine with this Briggs. It will not start on its own but I can force it to start by jumping it with cables to my truck battery. So long as I don't get out of the seat to engage the shut off switch it will run all until it runs out of gas. However if I stop it will not start until I jump it again. It acts as if the battery is dead and cant crank the motor fast enough to fire. I get about two thirds of a crank out of the engine and it stops there. I have a Craftsman mower with this same motor and it starts flawlessly every time. I have fully charged this battery and have even tried a different fully charged battery with same results. Can this engine be used as a replacement in this mower. I have myself convinced it is not wired correctly or may have the wrong voltage required to fire the engine. has anyone ever put this type of Briggs in a Cub? I will upload pictures later today to show you all what was attempted. maybe this will help others to understand better what I am dealing with. Very Frustrated at this point.........
