Does anyone have any experience with replacing a governor on a Cub Cadet RZT that has a Kohler 19 hp. engine. Spec. # is SV 590. This is the one that goes through the oil passage cover up into the closure plate. Has a governor shaft, a gear that runs in one of the gears of the engine, two counter weights, and a cap that goes over the inside end of the governor shaft.
