I have a Cub Cadet zero turn RZT L54 (MODEL NUMBER: 17BRCACA010) that I bought new in May 2015. A few weeks ago I was mowing and it died on me. Could not get it to start. Replaced the fuel filter, and nothing. Cleaned the air filter, and again nothing. I took the fuel system apart and could see that it was getting fuel. I then decided to do a spark test. I pull one plug, and went to start the test, and when I cranked it over, the engine started. Put it all back together and it ran fine the rest of the day. I did notice there seemed to be a very light coat of oil in the air filter housing so I replaced the air filter. Next time I mowed, I was mowing and the engine once again died. After a few times of cranking it, it finally started and I went about my day. I know something is wrong, but I don't know what. I believe it was last year it died while mowing and after leaving it awhile it finally started, but never had any issues till now since then. I've changed the oil regularly, changed the spark plugs, fuel filter now 2 or 3 times and replaced the battery. Any ideas on where to start?
