Hi all, I have a Cub Cadet 1450 hydrostatic mower, the deck will not raise. There is a handle on the right side of the steering pedastal that connects to a hydraulic unit on the steering column, the handle passes thru a connector link to the hydraulic unit and it appears to have a stripped pin. Is there an easy way to check this connection with out removing the whole pedastal?
