cub cadet gets hot
bardaqr
I have a cub cadet that I just bought(used). It has an 18 horse Kohler that runs really hot. The shrouds are all on the engine, but the side shields are missing. Will mthis cause overheating?
mechanic mark
bardaqr
Thanx for the reply Mark. The engine does not shut down it keeps running, but very hot. I was told that the side shields(TRactor not engine)being gone may cause this problem,~~~Barry
SeniorCitizen
I doubt the side shields are a factor unless they are built in some manner to direct atmospheric ambient air flow rather than air from around the engine. Some tractors have a similar design but that feature is often built into the hood. John Deere is an example.
Being this is a pre-owned tractor there is always a chance a previous owner has leaned the fuel for better economy and that can cause undue heating. Also be sure the engine is operating at full designed throttle, especially when under a load.
bardaqr
Thanx for the reply- I kind of felt that way myself, but I thought it would'nt hurt to check~~~Barry
mechanic mark
Post your model number & year, all numbers from engine, thanks.
bardaqr
It's a cub Cadet model #2000 year 1996 engine Kohler 18 horse ~~~Barry
