Cub Cadet fuse locations???
emp1953
I have a cub cadet 50" riding mower with a Kohler Courage engine. Was cutting grass when it just shut off. There's no dash lights or hour or voltage info either. Put a meter on the battery and it is perfect. Starter will not turn over. I found a pair of the headlight wires were off and they were touching each other enough that that has fused together. Easy to pull apart though. So I think these wires shorting out caused a fuse someplace to blow. I can't find anything, no info, on where to look for fuses on this mower. It's older maybe 2010-2011. Any help would be appreciated.
Thanks
Should be somewhere close to the battery or starter solenoid. If your battery is under the seat, I would start by removing the battery and look in that area.
emp1953
No the battery is not under the seat it is under the hood / engine cover. Its a model LT1050
Then the fuse is normally mounted with in 12” of the solenoid.
emp1953
It was the 20 amp fuse that was blown. Thanks for your help
MsLiz
My Cub Cadet is a 2009. The fuse location is in the attached photp.
