emp1953
- May 4, 2020
- 2
- 4
I have a cub cadet 50" riding mower with a Kohler Courage engine. Was cutting grass when it just shut off. There's no dash lights or hour or voltage info either. Put a meter on the battery and it is perfect. Starter will not turn over. I found a pair of the headlight wires were off and they were touching each other enough that that has fused together. Easy to pull apart though. So I think these wires shorting out caused a fuse someplace to blow. I can't find anything, no info, on where to look for fuses on this mower. It's older maybe 2010-2011. Any help would be appreciated.
Thanks
Thanks
