But clipping it off before trying to clean it is.Eliminating the pintle on the end of a solenoid does not make a person an “idiot”.
These solenoids are cleanable many times when they are gummed with old fuels. OR at least I clean them with ultrasonics when they are cleanable; Just cant use carb cleaner as that would destroy the rubber seal. Now they also can rust up, mechanically start jamming, short out or open up electrically.
Currently the Ruixing solenoids are the one are primarily shorting out but even this on the rare list.
And Rivets yes that is the correct PN for the Kohler version.
The problem was likely the OP was getting the Walbro version which has SAE threading and the Nikki uses metric threading. They are not compatible threading wise.
