Looks really good! Appears to have been well cared for, just used, but not abused. The Cub Cadet Lawnboys are one of my favorites. The color and graphics are just awesome. I'll bet you did just fine getting that governor assembled correctly. Just make sure that you didn't get the throttle over centered (rotated fully clockwise 12 to 1 oclock position) in getting it back together. When facing the lever it should be oriented to the 10 o'clock position, and it should have spring tension to push it back to that spot if manually moved. If over centered the speed can get out of control real quick. It will start at 10 o'clock and once it comes up to speed it should move down to the 8 o'clock pos, and when a load is applied it could be anywhere in between 8 and 10 depending on the amount of the load.
