if you are sure points and cond. good,probably need new coil but i would try p&c first. coil is quite expensive. should crank with bad volt. reg. but wont charge batt. when running
how have you made out on this problem. just wondering if you ever got spark,if not try turning key on and break and close points with a screwdriver. you should get spark at the points when doing this
