davbell22602
- Nov 27, 2011
- 152
- 1,324
New points, condenser, and spark plugs.
Turns over but wont start. Fuel pump isnt pumping fuel when pulling the hose off the fuel pump going to the carb. Wont even start on carb cleaner or pouring gas into the throat of the carb. Points set at .020. Any other ideas before I replace the fuel pump. New spark plugs
PO replaced points but not condenser and spiced broken condenser/coil wire back on points to get it to run. Points still in like new condition.
Battery has 12.80v. Coil has 11.18v but 9.xx volts when engine is cranking. Battery is a 2009 Rhino battery.
Kohler KT17 Lhead twin
