I have a 3648 zero turn. I was mowing and I turned off the blades to cross a ditch line, when I came back across I pulled the PTO switch to turn on blades, nothing happened but I did notice on the rpm gauge that it was showing rpm speeds like the blades were engaged. I drove the mower up to my shop and turned it off. When I tried to restart it, I will not start, no click, nothing. I was originally thinking it was the PTO switch so I replaced that but it still appears to not be working, that was however in the dark last night so I will try again in the daylight to make sure I got everything hooked back up correctly. Anyone experienced this before? Thoughts on what I should check next? The mower has never had a problem with blade engagement before this. I had actually engaged and disengaged the blade a few times before this happened.
Thanks
Thanks
