Cub Cadet LTX1050 22hp kohler courage
Ok so before i begin...yes i know and have heard bad things about the courage but it has worked well for me for the past 4 years. No issues with motor at all.
The problem I am having started with the starter gear sticking up in the engaged position. Battery was old and needed replaced anyway so I did that. No change.
Replaced solenoid ($15) and now the mower will start but I am getting a noise from the starter/flywheel gears while it is starting. Not sure what this could be? Teeth do not show any major wear or breakage.
Worn out starter?
Mower runs fine after starting and pinion gear drops down as it should.
Any help would be great
Worn out starter?
