john.page3
- Aug 25, 2014
- 1
- 4
My 2166 has a problem keep the battery charged.
I have replaced the voltage regulator.
Tested the system: Stator output 44 to 45 ac volts
Regulator putting out 12.69 dc volts to battery
I have replaced: Ignition switch, PTO switch, PTO unit, replaced voltage regulator.
Even with the Cub running at full throttle it will not stay running when I disconnect the battery.
If I charge the battery for a couple of hours it will run for about 3 hours than the battery is totally dead.
What I'm I missing?
What I'm I missing?
