Cub Cadet 1650 Wiring Diagram
notmenotme
I have a 1976 Cub Cadet 1650 that is still a wonderful lawn tractor/mower. I recently have had some intermittent electrical problems ranging from partial to total electrical failure. The battery and its direct connections appear to be okay.
I would like to find a source for a complete wiring diagram/schematic, but have not been successful so far. Can someone point me in the proper direction to obtain one?
sawman024
Hello,here's a link that might help.
  • 1650 wiring.pdf
notmenotme
Hello sawman024,
Thanks a million! That's a great help and exactly what I was looking for.
Best regards,
daky
KennyV
That is the same wiring as my 1450.... The common problem with electrical issues is the Key Switch...
It's location allows for water fowling the switch & the wiring plug behind the switch..
Usually requires a new key switch and cleanup of the wire ends... :smile:KennyV
SONOFADOCKER
I get a couple of these in shop each spring . Most we re-wire because age heat moisture has taken its toll on the few wires that there are .
