New Forum Member, 1999 Cub Cadet 1600, all belts original, cracked etc...replacing
I am looking for that post you found that discusses removal of the pto clutch to get the lower drive belt off of the engine pulley, not seeing it. The engine wants to turn over as you described when trying to remove the hex bolt on the pto / crank shaft. Owners manual does not discuss this specifically. Can anyone help please. I tried searching but no luck. Thanks!
