I inspectorted Forum Newbie Feb 24, 2013 #11 Same as mine. started smoking and pulled the head off and you could wiggle the piston so much oil would spill out of the cylinder. The spec # is 41612
Support Lawn Addict Community Leader Feb 25, 2013 #12 Welcome to LawnMowerForum! I moved your thread to the Cub Cadet forum. :smile:
NCTSMALLENGINEREPAIR Forum Newbie Feb 25, 2013 #13 inspectorted said: Same as mine. started smoking and pulled the head off and you could wiggle the piston so much oil would spill out of the cylinder. The spec # is 41612 Click to expand... I would use the 31C707 17.5hp
