cub cadet 1054 belts
krsmith
Ihave acub cadet 1054 that's 13 months old. Its in the shop for the second time because it keeps throwing the mower belt. Is this common? Is there a cure?
Carscw
Are you talking about the deck belt that runs the blades?
If its the timed deck then good luck worst thing ever was the timed blades.
(( racing is the only sport that you need two balls ))
