Repairs creeping in reverse
rvezakis
scag 36 " walk behind sw36a 13ka. In reveres mower just creeps if you pull on it it speed up. Have to pullon it to get it to go some times. thank you need help
Your machine is belt drive. As these systems wear, adjustments are needed to keep neutral where it is supposed to be. When the neutral adjustment can no longer be maintained, then parts need to be replaced. I recently serviced an older Gravely walk behind machine that was becoming dangerous to start and operate. I looked over the belt drive system and came to the conclusion that all of it needed to be replaced even up to the hand lever, the parts surprisingly are still available, but the customer balked at the cost.
Check the manual for your machine and make the adjustments or find someone who knows how and will do it for you. If your machine is a high time unit, then you may need to inspect and replace the worn parts of the belt drive system to keep your machine safe to operate.
