Hi,
Is there an easy way to measure the Crankshaft and Camshaft end play on a V-twin CV or CH Kohler Command?
I'm assuming the cover needs to be replaced and removed each time I measure this but the Kohler Service manual does not say that and the cover it'self is quite hard to get on and off.
Also, with the Camshaft, how do you apply side way pressure and where do you measure the end play from with the cover on?
Any tips anyone?
All the best.
Neo
Any tips anyone?
All the best.
Neo
