Cranks but no spark
JLOCKE
Kohler cv15s on a John Deere lx255 has no spark but cranks over put new module in and same thing
Remove the kill wire from the coil and check for spark again. No spark means bad coil.
.010 and make sure the coil isn't mounted upside down.
Should be Kohler coil part number 12 584 04. Air gap should be .010”. Did you buy an OEM coil from a reputable dealer or go to FleaBay or AmoScam to get your coil? Cant tell you the number of times we’ve encountered bad parts sold on the internet sites.
No bought from OEM from dealer so what is the right side up for coil
Looks like coil has an arrow on it. So the arrow will face you with the arrow pointing to the left. Which appears which will put the kill wire tab on top.
